• 30.11.2026, 22:32
Yukio
Leakshield fill port
Freitag, 5. Januar 2024, 09:20
Can use the straight plug&cool (90003) insted of the slot bracket (34143) or using a mini ball valve + fitting + soft tube
Many thanks in advance
Freitag, 5. Januar 2024, 10:18
You can simply connect a hose to your normal drain port and insert it into the water tank, the LEAKSHIELD will then suck the water into the system through the vacuum. You just have to make sure that the water does not rise up to the LEAKSHIELD, if the membrane gets wet, the LEAKSHIELD will no longer work until the membrane is dry again.
