• 12.11.2026, 19:55
jolly
Aquasuite wont send mqtt data
Dienstag, 23. Januar 2024, 18:03
Aquasuite Doesn't seem to want to send any MQTT data, even the test message I've even pulled up wireshark to sniff the traffic, and I don't see aquasuite even attempt to contact my mqtt server. Any advice?.
Mittwoch, 24. Januar 2024, 07:16
Sorry, without any information nobody can help you.
Have you testetd different brokers?
Test ist first only in your local network.
Some cloud services with mqqt support dosent work (aws, azure...).
Test it with a Mosquitto server.
jolly
Mittwoch, 24. Januar 2024, 19:11
I'm testing it on my local network, using an IP address not hostname.
I can connect to the mqtt server perfectly via a mqtt explorer on the same aquasuite pc.
I can sniff my network traffic and see my MQTT Explorer Reach out to the MQTT Server, however aquasuite never even attempts to contact the server
