• 30.11.2026, 23:45
DartSteven
[HELP and INFO] ULTITUBE D5 200 PRO LEAKSHIELD and ULTITOP DUAL D5
Samstag, 3. Februar 2024, 09:43
Good morning,
I wanted to ask if it’s possible to convert this ULTITUBE D5 200 PRO LEAKSHIELD into a dual ULTITOP DUAL D5.
Let me explain further:
I would like to remove the final part of the ULTITUBE D5 200 PRO LEAKSHIELD reservoir to add the final part of the ULTITUBE 100 reservoir. Are they compatible? And if so, where can I find this replacement piece?
Samstag, 3. Februar 2024, 09:55
You can only remove the D5 Pump from the Ultitube and attach the Pump to the Dual Ultitop.
You cant connect the reservoir direct to the ultitop.
when you have 2 D5 Pump you can use this:
https://shop.aquacomputer.de/product_inf…roducts_id=4203
to connect your ultitube with the Dual Top.
DartSteven
Samstag, 3. Februar 2024, 10:01
Thank you very much Sebastian,
you were really fast and friendly!
thanks again
