Du bist nicht angemeldet.
Conanti
Conanti
Conanti
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »InfoSeeker« (18. Februar 2024, 04:03)
Conanti
Mike817
Conanti
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Conanti« (20. Februar 2024, 00:38)
I do not believe having the Flow Next in your current orientation is an issue, as the device allows you to rotate the text 180°.)
So I absolutely would flip it if I could even just to test it. But There really isn't anywhere I can.
I have a High Flow Next in a test loop using soft tubing, sitting on a desk. It would be easy for me to invert it and see if it stops working. I will do so later tonight and let you know what happens.
Conanti
I do not believe having the Flow Next in your current orientation is an issue, as the device allows you to rotate the text 180°.)So I absolutely would flip it if I could even just to test it. But There really isn't anywhere I can.I have a High Flow Next in a test loop using soft tubing, sitting on a desk. It would be easy for me to invert it and see if it stops working. I will do so later tonight and let you know what happens.
I finally tried flipping a High Flow Next upside down in my test loop, while it was running. It made no difference in the flow rate reading at all. So I do not think yours is not working because of its orientation. Odd that it would fail after only 3 months. There is not a lot that can go wrong. I was thinking maybe a bad cable or damaged connector but you said it is showing up in AQS and you are getting other data from it. Aquacomputer usually responds to emails in a day or two. Hopefully you will hear from them soon
Conanti
