• 22.11.2026, 22:19
cptninc
Anyone run a dedicated PSU for your Aquaero system?
Mittwoch, 21. Februar 2024, 05:25
I'm looking at building a standalone cooler that is external to my PC (like a MoRa but fully standalone). It seems like giving this a dedicated SFX form factor PSU would be massively wasteful plus be undesirable from a packaging standpoint anyway.
Is there anything else I should be looking at?
The cooler will have an Aquaero6 XT, dual D5 NEXT pumps, up to 13A of fans, a handful of temp & flow sensors from the aquacomputer ecosystem, and a USB hub.
Dops
Mittwoch, 21. Februar 2024, 13:04
You should probably try to distribute the current load across several power rails. and install a switch in case of emergency.
translated with Google
cptninc
Mittwoch, 21. Februar 2024, 20:56
I actually don't want to use an ATX PSU for this at all. I was hoping someone might know of a small and simple unit that has no outputs other than 5V and 12V. Maybe something like an old laptop power brick?
Dops
Mittwoch, 21. Februar 2024, 21:11
OK. I understand. I have no idea about this, but modern notebooks have USB-C. That's how I know it from DELL. Maybe this is something for you.
I once needed an external power supply for 2 giants and built a stainless steel box for the ATX power supply. It was a lot of effort but it looked good.
Remayz
Mittwoch, 21. Februar 2024, 21:46
there are power supplies with a molex connector. with a suitable splitter i imagine that'd be all you would need.
That missing ground lug is annoying though.. when i used that i had to solder a bridge between the grounds on the splitter i was using.
