• 20.11.2026, 02:53
themule08
Having issues getting Aquero 6 pro to connect to two quadros
Montag, 4. März 2024, 19:59
I have connected both quadros to USB headers and assigned different addresses.
I can get them to work though the USB port with a fan curve for temperature of the water, and the flow sensor works as well.
Once I connect them to the Aquero with the aquabus x4 nothing works, and the Aquero does not show anything on the screen like it is not getting power. Once I remove the aquabus cables from the X4, the aquero shows stuff on the screen again.
Not sure where to go from here..
Thanks
Methodical
Freitag, 8. März 2024, 20:25
Did you assign them the appropriate code category. I tried to find the categories/codes in the manuals but they were not jumping off the page for me. Did you try that button "find aquabus devices" in the AQ6 aquabus tab?
Update. I have the X4 and Octo connected to the AQ6. The X4 is assigned 112 as the Aquabus Hub and the Octo has no code.
Dieser Beitrag wurde bereits 4 mal editiert, zuletzt von »Methodical« (3. April 2024, 03:46)
"Never be afraid to try something new. Remember, amateurs built the Ark, professionals built the Titanic"
roadruner2023
Mittwoch, 27. März 2024, 11:18
see User and installation manual page41-46.
Methodical
Mittwoch, 3. April 2024, 03:43
Did you resolve the issue?
