• 03.10.2026, 01:14
Stitchypoohs
Octo and High Flow Next
Freitag, 26. Juli 2024, 04:52
Hello and thanks for help in advance. If I'm using the Octo and Flow do I just need to use USB for each? Will all relative data and RGB from the Flow be carried over USB? I've read the aquabus is not needed, but do I need to hook up flow, temp, or RGB if I strictly use USB? Thanks again.
Freitag, 26. Juli 2024, 07:19
Just connect both via USB.
You can control everythink with the aquasuite Software.
Stitchypoohs
Samstag, 27. Juli 2024, 06:38
Thanks for the help and reply!
