• 12.10.2026, 16:11
DumpTronald
Corsair 1000d Obsidian 32 radiator fans and two Active splitty 9s
Samstag, 3. August 2024, 13:47
Hi all , I've been using the Octo for 2 years now on my current build , but my
new build will have four push/pull 480mm radiators.
So 8 fans per radiator, so two radiator's have Noctua NF-F12 PWM , amps 0.05 per fan.
The other two have Phanteks T30s, amps 0.16 , performance setting.
The plan was to use two splitty 9 active to run the 16 fans on each set of radiators, using a spliter cable to create 8 fan cables per set of radiators.
So each splitty 9 fan header would run two fans , the 16 T30s would draw 2.56 amps and the 16 Noctuas 0.08 amps.
I read that the Noctua fans don't play nice with splitter cables so but I already have 9 Noctua NF-F12 , so I had hoped to reuse them.
Currently running the 3 of the Noctua fans from one header on the Octo gives me ramping issues ( see first pic ) because the PWM signal is compromised, would only running two from an active splitty fix this .
Thank you.
Also my main concern is that 16 fans on one Splitty 9 active might be to much ? , for the PWM signal and power wise .
Should I get two more Splitty 9s , this would mean A LOT of cables .
Adding some pics , the one with the jagged fan profile is the three Noctua NF-F12 running from a 3 way spliiter to the fan header on the Octo , the other is the T30s run in banks of 3 with the flat profile , they are all
controlled from the water temp sensor.
The T30s seem to have no problem with the PWM signal on fan splitter cables , I thought the splitty9 active would solve this issue with the Noctuas but now I am not so sure . I am going to have to connect a splitty9 to
the Octo with 8 noctuas connected to 4 fan headers .
If that fails I will have to try one fan per header if that works then buy more Splitty9s if not then ditch the noctuas and buy more T30s or Arctics 120s .
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »DumpTronald« (4. August 2024, 14:28)
