• 22.11.2026, 21:41
prosps
PUMP ROTATION FLOW DIRECTION
Mittwoch, 25. Dezember 2024, 22:16
Hi, everybody. The question is simple as a day.
Can I change the direction of the pump rotation by wires or by software?
(first generation pump D5 next with rgb light)
And if yes. How i can do this ?
Thanks for help anyway.
Remayz
Samstag, 28. Dezember 2024, 02:34
you can't change the rotation of the pump no, and that would just kill waterflow if you did anyway since pump tops are made for the pump to spin one way only.
if you need to reverse the flow, you'll have to swap connections.
