• 16.10.2026, 20:22
WaterBoy61
Please Help Setting Aquasuite Again
Sonntag, 2. Februar 2025, 16:22
I need help setting up Aquasuite again. It has been almost 3 years ago since you helped me the first time. I can`t remember how to do this, and I cannot figure out how to change things after I added components to my PC. I added a MoRa3 420 and a High Flow Next in the water loop. Also changed all the fan and pump connections to the Octo. I now have the 3 fans on the top radiator daisy chained and the 3 bottom radiator fans daisy chained. They are no longer monitored individually. Here is a screen shot of the overview page how it looks currently. The HF Next is not set up right, the fan channels need changing, the ambient temp is not reading, and the water pump is showing zero flow. I have a DDC pump on the Distro plate and 2 pumps on the MoRa. Can Aquasuite show and control all 3 separately and be controlled by water over ambient?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »WaterBoy61« (2. Februar 2025, 17:23)
WaterBoy61
Dienstag, 4. Februar 2025, 00:04
Anyone know how to set up devices and change some sensor`s? I need to change the fan curve to be controlled by "water over ambient". I don`t remember how to set things up after 3 years, and I cannot find anything online that shows how to work with Aquasuite.
Dienstag, 4. Februar 2025, 07:16
https://aquacomputer.de/handbuecher.html…CTO_english.pdf
What you are currently seeing are the overview pages.
You have to go to the relevant device and change the settings under Fan.
Dienstag, 4. Februar 2025, 14:05
Hopefully this gets you started (SETUP)
WaterBoy61
Samstag, 8. Februar 2025, 00:36
I figured out how to rename all the sensors and fans/rads on the Overview page. But, they will not stay on the new names I gave them. Aquasuite keeps reverting back to Sensor 1, Sensor 2, and the fans have no names on them. Why won`t the Overview page keep the new names I give the sensors? I also still need help on how to get the High Flow Next to show it`s data on the overview page too.
SgtSixpack
Montag, 10. Februar 2025, 21:56
Water temperature over ambient is found by using the "playground". Then import that as a value to your quadro/octo/fan controller.
https://imgur.com/a/aquadcomputer-playground-NWr8qph
Where are you placing your ambient temperature probe? I find that the case temperature mimics the water temperature. I have made a playground value which takes the water temperature from the high flow next and adds that to a dial I defined as 0-15'c. Then I set my fan control mode to target temperature of 36'c and my water temperature is about 26'c now; so if I want the fans to ramp up I use the dial to make the playground value closer to target temperature.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »SgtSixpack« (10. Februar 2025, 22:03)
WaterBoy61
Dienstag, 11. Februar 2025, 17:18
"Water temperature over ambient is found by using the "playground". Then
import that as a value to your quadro/octo/fan controller."
That part is okay and still in my Playground. It just will not hold the assigned name I give it.
"Where are you placing your ambient temperature probe?"
Mine is plugged into my Octo and the sensor end is just hanging out the back of my PC case. The assigned name for this also does not stay. And in the HF Next dropdown, I cannot make any calibration s to the HF Next. the software runs fine, just not the names and calibration part for everything.
SgtSixpack
Mittwoch, 12. Februar 2025, 17:36
You don't change the name on the overview page. The place to change names is under the octo tab, high flow next tab or playground tab. The overview page is just a quick reference not where you configure anything.
WaterBoy61
Donnerstag, 13. Februar 2025, 23:46
Yes, that is how I was doing it, but the names do not stay. On the next AC start up, all the names are gone.
