• 22.11.2026, 22:43
SgtSixpack
I want an additional temperature sensor in my loop so that I get a power disipated reading from my High Flow Next.
Dienstag, 4. Februar 2025, 20:28
I've been looking at temperature sensors. I though it would be a plug/end stop rather than a pass through sensor. I've seen a plug type, just not aquacomputer. Is there a reason that the aquacomputer temperature sensors are pass-through and not plug type? Or could you put a plug on the end of one and put it on a blank port of a GPU waterblock for instance (I have a plugged port that gets sprayed directly on my GPU waterblock).Edit: I think I could easily add it to the inlet of my GPU, with the tube fitting on top (maybe not that easy as it means draining the loop again).
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »SgtSixpack« (4. Februar 2025, 20:33)
Dienstag, 4. Februar 2025, 22:16
In order to get an accurate dissipation number for the radiator, you should have the two temperature sensors close to the radiator inlet and outlet ports.
I don't believe it matters which sensor is at which end, the builtin calculator uses the absolute difference.
The high flow next has a temperature sensor internally, so just one additional sensor is needed for the external temperature port on the high flow next.
Any one of these three should do. (SENSORS)
