• 17.11.2026, 09:35
Aurosonic
High Flow Next to Aquaero
Mittwoch, 23. April 2025, 22:18
Can't figure out how to add flow rate data from High Flow Next flow Sensor to Aquaero sensors to be able to make Power Consumption measurements.
Any tips ?
SgtSixpack
Mittwoch, 23. April 2025, 23:36
Use "data source" to a soft sensor on the Aquaero. Its on the 2nd screenshot.
Aurosonic
Donnerstag, 24. April 2025, 01:12
Cant find it
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Aurosonic« (24. April 2025, 01:22)
Aurosonic
Donnerstag, 24. April 2025, 01:27
Was able to find it at Quadro Soft Sensors Data Source but it doesn't appear in Aquaero flow sensors to chose for Power Consumption
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Aurosonic« (24. April 2025, 01:34)
Bartdude
Dienstag, 29. April 2025, 07:44
As far as i'm aware the only way possible to add it is via Aquabus connection
