• 17.11.2026, 19:05
bigjimmyauk
Can not get aquasuite to auto start with windows boot up
Samstag, 31. Mai 2025, 02:20
Been having this issue for a while now, while the service starts fine and all functions automatically take place like my fan profiling from water temp etc. I can not get the aquasuite program itself to auto start with windows, as i have custom monitoring pages and i like it to log the data it's frustrating having to manually start aquasuite before hand.
i've tried manually adding to the start up folder
changing the affinity and priority of the process
enabling admin mode across all accounts
adjusting the in program settings, exiting and trying again.
not once have i been successful in getting it to auto start with windows. either minimized or not
any help would be appreciated
Mittwoch, 4. Juni 2025, 09:02
The auto start of the aquasuite uses the Windows task scheduler. Maybe check if you can spot any obvious problem there.
First thing that you should try is to simply raise the start delay: run the aquasuite with admin rights and in the aquasuite -> settings tab you can change the start delay to a quite high value like 10 seconds just for a test. If that helps, you can still try to lower the value step by step until the problem is back again. It is possible that the aquasuite does not run immediately after the system start because some other required stuff is not loaded yet. You could take a look into the Windows event manager. It might be possible that there are even error logs for the aquasuite because of such a problem.
If it is just a configuration problem with the task scheduler it often helps to run the aquasuite with admin rights, disable the autostart in the aquasuite -> settings tab and then close the aquasuite. Check the task scheduler for a "aquasuite autostart" entry and remove it manually if it still exist. Do not remove the "aquasuite service helper" entry.
Start the aquasuite with admin rights once again, enable the autostart, close the aquasuite and check that the "aquasuite autostart" entry exists in the task scheduler. If so, restart the system and hopefully it works now.
The previously mentioned start delay could also still play a role.
