• 15.11.2026, 14:37
MateuszT
Confusion on Desktop mode element placement
Dienstag, 15. Juli 2025, 06:54
Hello,
I have two monitors, one with 1280x800 resolution and one main with 2840x2160 resolution set up like this:
I know from this thread: Aquasuite Desktop Display Request to Developers
that Aquasuite is taking those two as a one big screen, so in my logic if I want to show desktop on 3 monitor I should place all elements in top left corner.
But I have problems with this: Need to make an offset on X axis by around 230 Pixels because if not, then the view is cropped from left side.
What I am doing wrong ?
Dienstag, 15. Juli 2025, 08:54
I assume you are using different scaling settings for these monitors? If so, it is a known behavior caused by the way how .NET applications handle differently scaled monitors.
MateuszT
Dienstag, 15. Juli 2025, 11:45
Oh.. that was the issue, thank You very much !
