• 13.11.2026, 00:15
Stark
Kryos Next orientation
Mittwoch, 13. August 2025, 00:33
Good day.
Just recived Kryos Next with Vision and have question about orintation of water block.
I am using 1151 socket motherboard, and technicaly water block could be installed in all 4 directions.
If i anderstand instruction corectly, it should be installed with screen down.?
in this case the central inlet fitting interferes greatly with the tube to the video card (I'll have to make a 180 degree turn and then another 90 degree turn, crazy). Explanation: i have radiator on top of the case ( incoming flow)
Yes i can rotate waterblock 180 degree. In this case creating loop is much easer, but there is a problem, i do not see anything on a screen because of feeting and tube...
So the question, is:
Is it officially allowed to rotate the water block by 90 degrees? (with the screen facing the RAM)
Or will this have any consequences?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Stark« (13. August 2025, 00:42)
