• 21.11.2026, 16:43
chrislocho@gmail.com
How to use High Flow Next as a temperature sensor outputting the temp signal into Quadro.
Donnerstag, 14. August 2025, 08:16
Currently putting together a set up with the High flow NEXT and the Quadro, I have heard that the aquasuite software would not need to be run in background if the data it needs is fed directly into it. I wanted to ask how to output the temperature data from the HF NEXT direct to the Quadro ? I am very confused by t he many cables needed.
Is this possible or will I need to get a separate temperature sensor to plug into the Quadro ?
Thanks!
Donnerstag, 14. August 2025, 09:46
This is only possible with the background service.
The sensor is transferred from the flow sensor to the other device as a software sensor.
Both devices must be connected to the PC via USB.
