• 19.11.2026, 22:01
Marraz
Aquero 6 pro not mapping Temperature sensors from aquabus devices
Freitag, 5. September 2025, 03:21
I just install an Aquaero 6 Pro, OCTO, high flow NEXT, a calitemp and a few other passive temperature sensors, I connected everything to the aquaero via aquabus using a aquabus X4, I am able to control all the fans, the flow sensor is detected correctly, the calitemp shows as expected, the only thing that it are not working are the temperature sensors in OCTO and high flow NEXT, I can use configure the fans in the OCTO and see the flow sensor in the NEXT but the temperature sensor just doesn't appear.
The aquabus tab of the aquaero does show the temprature sensors and shows how are they suppose to map in the aquaero, is just that those sensor doesn't exist
Here is a thought, the mapping is not as the aquabus tab says, the tab displays this for OCTO:
Temperature sensor 1 -> Temperature sensor 9
Temperature sensor 2 -> Temperature sensor 10
Temperature sensor 3 -> Temperature sensor 11
Temperature sensor 4 -> Temperature sensor 12
On high flow Next:
Temperature -> Temperature sensor 29
Water temperature -> Temperature sensor 30
If I sort of cross reference with the manual, the Temperature sensor 9 is actually been shown as poweradjust 1 and the Temperature sensor 29 is actually mps 1 internal. And I have a feeling this is the case now. If that is the case, then the manual is very confusing and the aquabus tab is misleading, doesn't make sense that it doesn't tells me the actually naming of the sensor.
