• 30.11.2026, 23:03
gDavid
Can someone please explain how to duplicate a global profile (in order to modify and save) as a distinct option?
Sonntag, 5. Oktober 2025, 03:57
Hi all, been lurking a while and have some rather loud fan setups controlled by ambient-water temp Delta.I'd like to duplicate the default profile in order to modify it to create a "Target Temperature" profile as discussed here; particularly after re-reading Capt-Clueless' posts within the subject F.I:
I'd argue that controlling deltaT is a dumb idea compared to just
controlling absolute water temperature, but that's a minor point
compared to the flaws in using a curve controller instead of set point
control. And I'm truly baffled by the amount of replies this post has
gotten without a single mention of it.
I'd like to do more with my liquid cooling and this can allow me to test and hopefully improve my setup.
Just about to do a new build and still time poor, so anything that can help save time and speed up improvements should be good.
With thanks from the antipodes
gDavid
Montag, 6. Oktober 2025, 03:46
After a friend came over for a couple of fittings to replace a problematic one in his new build I put some work into a test profile.
  1. Took a backup.xml of my Quadro settings
  2. Reset Front INT rad fans to sense Coolant temp 39C & hold minimum 10%
  3. Reset Top EXH rad fans to sense Coolant temp 39C & hold minimum 12%
  4. Reset Rear EXH rad fans to sense Coolant temp 39C & hold minimum 12%
Alles ordenung :) Quiet is real
Remayz
Montag, 6. Oktober 2025, 10:40
controling absolute water temp is fine when your ambient doesn't change much. that dude on reddit must have AC all year long to say stuff like that :p
I'd argue that delta T should be quieter and occasionnaly hotter when the ambient temp rises of course, so your noise problems are honestly probably just a matter of tweaking the fan curve than a problem with the type of control. A badly set PID control can give the exact same outcome.
The way i see it is PID focuses on maintaining a certain temperature, and delta T focuses on maintaining a certain max noise level. Depends what you're after.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Remayz« (6. Oktober 2025, 10:55)
