• 21.11.2026, 21:03
KlimentVoroshilov Type-1
Questions about the RGB support of Aquacomputer's products
Mittwoch, 14. Januar 2026, 12:37
I'm just a newbie, have been following aquacomputer for months. May actually start to build my own loop next year and thought AQ's products are my best choice. However I noticed most of the products only support AQ's own RGB standard, such as high flow next sensor which normally controlled by USB connector. I've found there is a RGBpx connector behind it but the website said it's used for controlling other devices, not for inputting ARGB singal. May I use official ARGB to RGBpx adapters to control HF next sensors or leakshield? Or I just need aquasuite for RGB control? If aquasuite is the only option, can it sync with other softwares such as MSI center? I just really don't need no more softwares for RGB control :S
fiershrimp
Montag, 26. Januar 2026, 19:42
I am new as well, but to the best of my understanding most of aquacomputer's aRGB is designed to be managed by the aquasuite. MSI center and other hardware vendor made management will be hit and miss, with more misses then not. I would suggest looking into a standalone aRGB service if you have more then one vendor. I know SignalRGB has added aquacomputer D5 NEXT pump and highflow NEXT. I'm not a fan of a subscription model but they have been super good about support. If open source is more you speed, OpenRGB doesn't support any aquacomputer lighting at the moment; but if you are willing to put in the work open source is good for a reason. OpenRGB is also lower resource hungry then SignalRGB.
The biggest problem with getting the aRGB on the LEAKSHIELD to work is on the aquasuite side. There doesn't seem to be a way to pass-through aRGB data for the LS. I can get the highflow and D5 pump I'm running to be found by SingalRGB after tweaking some settings and ending aquasuite's servace (this does limit aquasuite monitoring and software alarms). But the LEAKSHIELD doesn't have the options in settings. I am trying to find the correct place to message auquacomputer about this right now. That and translate my question into German.
