• 30.11.2026, 22:19
JetFlightr
Feature Request to aquaSuite to increase limits.
Donnerstag, 12. Februar 2026, 13:38
Hello, i am using aquacomputer octo , i have fans that go above the maximum supported fan speed in the Fans tab, click the fan header to configure, then
"maximum fan speed for bar graph and chart" you then go upto 15000 here, my fans go above 15k rpm This causes the graph to become improper at full speeds. I wish for this limit be increased in some future update :) to see my fans graph better at full speed.
Fan being used: artic 4028 15k real speed: more than 15k rpm, which causes graph to get flat.
This is a nice to have.
Railgun
Samstag, 14. Februar 2026, 14:48
The spec of that fan is 15,000 RPM at the top limit. Anything above is probably just a variability. While I appreciate you saying it’s a “nice to have,” it’s probably a non-issue in reality.
What does the graph do other than flatline on the high side?
JetFlightr
Freitag, 20. Februar 2026, 11:42
Indeed, it is a non issue just a nice to have.
The graph does nothing other than a flatline when at full speed as expected
