• 22.11.2026, 20:30
AlphaS7
Problem with high flow sensor NEXT
Dienstag, 25. August 2026, 16:13
Hi everyone, I built my first liquid-cooled PC.
I have fans connected to the OCTO and a high-flow sensor, but the flow reading only shows up when I set the pump to 100.
It’s a D5 pump in an EKWB distribution plate.
I don’t know what could be causing this,
and I also don’t know how to configure all these fans, so I’ve left them set to 30% in auto mode.
I have the Octo USB, the fans, and that temperature cable connected. The flow meter is connected separately via a USB cable.
»AlphaS7« hat folgende Bilder angehängt:
»AlphaS7« hat folgende Dateien angehängt:
  • auqsui.JPG (691,62 kB - 419 mal heruntergeladen - zuletzt: Heute, 20:19)
  • IMG_0542.jpeg (1,53 MB - 387 mal heruntergeladen - zuletzt: Heute, 20:19)
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »AlphaS7« (25. August 2026, 16:49)
Dienstag, 25. August 2026, 21:48
Your loop maybe a bit restrictive, only getting a flow rate of 35 l/h at full power.
The high flow next sensor "delivers reliable readings over a wide range of flow rates between 35 l/h and 1000 l/h".
