• 22.11.2026, 20:30
mikeyt
Fan profile Help
Montag, 19. Oktober 2026, 10:44
Hello how do I save a fan profiles on the picture below I have 3 fans at 40 that's my silent mode when I put them to 60 for gaming how do I save a profile tried everything but it just stays at the settings I have set.
»mikeyt« hat folgende Datei angehängt:
  • 1.jpg (295,74 kB - 111 mal heruntergeladen - zuletzt: Heute, 20:19)
baazaar13
Dienstag, 27. Oktober 2026, 07:26
If you want actual profiles, you would go into the profiles tab under OCTO setting in the left sidebar, and configure the different settings for the fans with the profile number you want those settings to be attributed to. There are better ways to handle the fans tho, you can just configure them to change in one profile, as a function of some temperature, such as water temp or air-water temp difference. You just have to make sure the curve fits the output you want.
