• 22.11.2026, 20:29
BallinOuttaControl
Alarm kept going off during demanding games on new Ampinel installation using a power extension cable with a sharp turn in it(GPU cooler was in the way so I couldn't install directly to the card). Now I got a new CPU cooler and I installed the Ampinel dir
Sonntag, 1. November 2026, 05:15
Installed Ampinel with power extension cable because CPU cooler was in the way and with a sharp cable turn out of my GPU because my case glass was very close. I tried to play Gear E-Day and the alarm would go off every 2 minutes so I'd quick close the game and the alarm would stop I'd wait 30 minutes then try again and it kept happening maybe 4 or 5 times but after getting a new CPU cooler and plugging on the Ampinel directly to my GPU and removing the extension cable from the setup I'm not triggering the alarm anymore. Is it likely because I removed the extension or because I removed the sharp cable turn or both or maybe just a poorly constructed extension cable? I might try using the extension again briefly but with the Ampinel still connected directly to the GPU. I did just get everything installed and would rather do some gaming but if someone wants me to put the extension in between the psu and the regular power cable or between the regular power cable and the Ampinel I can maybe do that at some point in the next few days.
But ya either the sharp cable turn or the extension in general or maybe a bad extension or some combination of all of these was causing power balance or heat issues with the Ampinel picking them up what are people's thoughts on this?
Big Sean
Montag, 2. November 2026, 02:15
I had very similar issues when i had Lian Li wireless strimer LED cable extensions installed. The instant that i replaced the "Native" POS cable from Seasonic and Lian Li Strimer Extension cables with a CableMod 12vhpwr cable, all of my issues magically disappeared and have never returned. Now all of the pins show green in AquaSuite and i haven't had a single alarm go off with well over 20hrs of gameplay at full load in a variety of titles including Crimson Desert, Ace Combat 8, Gears of War E-Day, Forza Horizon 6, and Call of Duty Modern Warfare 4. Never use the Lian Li Wireless Strimer RGB cable extensions or any other extension cables or adapters that increase resistance and cause voltage droop. The 24 pin Strimer was causing my 5V and 3V rails to droop which caused a few of my usb devices like the lcd screen on the front of my Cooler Master HAF 700 evo case to randomly disconnect and trigger that annoying windows usb chime at random intervals. Once i removed the Strimers and used exclusively the CableMod cables, all of my issues are gone. The Ampinel is a wonderful device and gives me a great piece of mind that my RTX 5090 Astral OC will be safe for many years to come in my custom loop system.
System Details
Asus PG34wcdn UWQHD Ultrawide Monitor with Asus ROG Aura Light Bar with Ergotron LX Pro adjustable arm with quick disconnect and grommet base
Acer Predator X27 4K IPS Monitor with Ergotron LX Pro adjustable arm with quick disconnect and grommet base
Cooler Master HAF 700 Evo Case
Ryzen 7 9850X3D with Alpha Cool Apex One Water Block
32GB DDR5 6,000MTs CL26 V-Color Manta X-Sky with EKWB Quantum Momentum Ram Water Block
Asus RTX 5090 Astral OC with EKWB Vector 3 Water block & Aqua Computer Ampinel device & Cooler Master GPU Holder with ARGB Tempered Glass
Asus Crosshair Glacial X870E
2x WD Sn8100 4TB Raid 0 array
Samsung 990 Pro 4TB
2x EKWB D5 Inertia G3 Pumps with Acrylic ARGB Top in series
Aqua Computer High Flow Next ARGB In-line Flow Sensor
FLT Kinetic 360mm D5 Reservoir/Pump Distro Plate
2x EKWB X360M Quantum Surface Radiators with Corsair LX120 & LX120R Fans in Push/Pull Configuration
2x EKWB P360M Quantum Surface Radiators with Corsair LX120 & LX120R Fans in Push/Pull Configuration
1x EKWB X240M Quantum Surface5 Radiator with Corsair LX120 & LX120R Fans in Push/Pull Configuration
2x Cooler Master Sickleflow 200mm ARGB Front Intake Fans
Razer Nommo V2 Pro 2.1 Speakers
Keychron Q6 HE 8K Keyboard
Razer Basilisk V4 Pro Mouse
Razer Firefly 2 ARGB Mouse pad
Desky Dual Hardwood Pheasant wood Sit/Stand Desk with 2x Grommets & Pheasant Wood under desk cabinet
