• 22.11.2026, 20:30
gaben25345
Aquaero 6 Pro with 3x D5 Next
Sonntag, 15. November 2026, 07:49
Hi everyone,
I have a quite restrictive loop, would like to add a 3rd D5 Next and control it with my Aquaero 6 Pro. Checked the manual and it says the maximum of 2 D5 Nexts can be controlled via aquabus (I use 1 splitty to mess with multiple aquabus sources). If that is the truly case, do you have any suggestion how to solve this? The issue is I am running out of PWM headers too plus I use Linux therefore direct USB + AquaSuite is 100% not an option either, aquabus would be the preferred way. Thank you for helping.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »gaben25345« (15. November 2026, 10:22)
Dops
Sonntag, 15. November 2026, 21:53
My two proposed solutions:
a) A second aquaero for the third pump.
b) A DDC pump.
Your issue with the limited number of PWM headers can likely be resolved using a PWM splitter—or you could go with my first suggestion.
Bartdude
Dienstag, 17. November 2026, 08:41
Just add a Quadro This is what I did to add extra PWM headers, also a lot cheaper than adding another Aquaero
Dops
Dienstag, 17. November 2026, 09:14
But that doesn't solve his problem with the third D5.
