• 29.09.2026, 08:48
Halk
How Tight?
Donnerstag, 3. März 2005, 23:07
Installing Aquacomputer into my new V2000B, how tight should I be turning the connections? I realise I can use a spanner, but I'd rather not apply to much pressure should it be enough with the pressure I can apply with my fingers?
If I leaktest it, and it's leak free, will it remain leak free?
NikoMo
NikoMod
Re: How Tight?
Donnerstag, 3. März 2005, 23:24
hi, and welcome to the board :)
a little bit more than you can apply with your fingers is the best.
normally it should be and stay leak-free, after you've made a leaktest.
Halk
Re: How Tight?
Freitag, 4. März 2005, 00:04
Thanks for the welcome.
Another little question, turns out the bottom of my Cuplex Pro wasn't completely flat, so I'm lapping it down to 2000 grit. I guess I just got the last one made on a friday afternoon?
back_orifice
Re: How Tight?
Freitag, 4. März 2005, 00:08
if the cooler is not useable, or if the cooling performance would get lower by this, i would send in the cooler, AC will surely send you a new one...
Halk
Re: How Tight?
Freitag, 4. März 2005, 00:12
Oh, it's usable, but lapping (using sand paper/glass paper) will give a better finish. I just noticed that the block I have wasn't flat. It's almost flat now though, and will be completely flat and have a mirror finish by the time I'm done :)
back_orifice
Re: How Tight?
Freitag, 4. März 2005, 00:26
diy rulz... ;D ;D
