• 03.10.2026, 19:02
Sam808
How to Clean the Cuplex?
Samstag, 26. März 2005, 02:06
Hi All,
I was wondering what's the best way to clean my Cuplex v1.0
I've had it installed & runninig since Sept 2001 (just with distilled water)
Now that I've upgraded to AMD64, I've had to take it all apart.
The outside (exposed to the air) is fine, still shiny copper!!!
but the inside has corroded a bit, though most of it looks like a thin film of algae.
I was going to use coke cola, but thought I'd better ask first ::) Any idea's...?
Re: How to Clean the Cuplex?
Samstag, 26. März 2005, 02:31
Use citric from pharmacy or supermarket.
Cola is a bit gluey ::)
Samstag, 26. März 2005, 03:33
i think you should clean your CuPlex two times...
the first time you should use alcohol (Disinfectant or something else)...
The second time you sould use citric acid...
After this two cleanings you have a brand new CuPlex! ;)
Man In Blue
EDIT:
And don't ferget: only use distilled aqua with AC-Fluid (or G11 / G12)...
NikoMo
NikoMod
Samstag, 26. März 2005, 11:06
WARNING
don't use alcohol for cleaning the plexiglass part of the cuplex. it might damage or maybe destroy it.
for this you should use normal glass-cleaner (or simply water)
Katzenfreund
Samstag, 26. März 2005, 11:37
Zitat von »NikoMo«
WARNING
use just water.
most glas cleaners are based on alcohol.
Don't forget to clean your Copper with water after use the citric.
Sam808
Samstag, 26. März 2005, 16:30
Hi All,
Thanks good tips ;) "WARNING
for this you should use normal glass-cleaner (or simply water)"
Opppss!!!! hehe.... done that already :-/ well it was Meths
Citric...? what's that, lemon juice or what? (that must sound really dumb) :P
ps how do I get the grey box into the post?
Katzenfreund
Samstag, 26. März 2005, 16:45
to make a quotation use "zitieren"
and yes, it's lemen juce. (or chemical lemen juce)
back_orifice
Samstag, 26. März 2005, 17:00
LEO says its "citric acid" ;D
aviddigi
Samstag, 26. März 2005, 20:01
ketchup and a rag, someone had brought me a danger den cooled 6800 block. NO copper color just green monsters all around, Ketchup on to the rag or tooth brush then i used a metal polish called FLITZ to get the shine back.
Sam808
Samstag, 26. März 2005, 20:11
Nice Tip aviddigi,
But I think I'll give that one a miss! ;D
Sam808
Samstag, 26. März 2005, 20:16
Nice Tip aviddigi,
Phew..... Got it right this time ;)
