• 22.11.2026, 22:13
edboswell
AquaDrive Mirco Harddrive Cooler
Donnerstag, 5. Mai 2005, 17:58
AquaDrive Mirco Harddrive Cooler The AquaDrive Micro installs under the HDD and fits in the standard 3.5 Inch drive. But because of its design is it possible to cool a hdd underneith and (its purpose) the hdd above?
Ze@lot
Re: AquaDrive Mirco Harddrive Cooler
Donnerstag, 5. Mai 2005, 20:38
id say putting it on top would be better, as heat rises so
the hottest part of the harddrive is the top. also the top
of a hard drive is all metal giving a good contact for the
cooler. where as the bottom is 50/50 metal & curicit board
so not much contact with the harddrive.
Mr_modnaR
Donnerstag, 5. Mai 2005, 21:22
if you look at:
http://www.aquacomputer.de/cgi-bin/shop5…d_micro_500.jpg
you can see that the cooler has a bolted on top plate with the AC logo on it, i think the bolts would get in the way if you tried to cool two hard drives with it! :(
