• 09.10.2026, 11:45
MaxManus
Hove many fans can aquaero supports ?
Freitag, 13. Mai 2005, 19:24
I have 14 fans in my computer. Can I use aquaero to control all fans ?
Which equipment do I need so aquaero can support further then 4 fans?
Top_Nurse
Re: Hove many fans can aquaero supports ?
Freitag, 13. Mai 2005, 19:38
My favorite question to ask in the Emergency Room when people come in drunk is: How many drinks? And they always answer 2! And my next question is and how big were those drinks?
MaxManus
Freitag, 13. Mai 2005, 20:02
I really have 14 fans in my self-made U2-UFO cabinet.
http://mountainmods.com/index.php?cPath=21_32
Top_Nurse
Freitag, 13. Mai 2005, 20:26
And how big are those fans? There is a 5 watt limit to each channel, but I have "heard" that it can be exceeded up to about 7 watts. So if you have fans that take 2 watts you could conceivably us 2-3 fans on each channel
MaxManus
Freitag, 13. Mai 2005, 20:40
4 X 80mm Coolermaster UV Blue Silent fan - 1.08 Watts
7 X 120mm Coolermaster UV Blue Silent fan - 0.60 Watts
3 X 120mm Panaflo FBA12G12M - 4.08 Watts
Ze@lot
Freitag, 13. Mai 2005, 21:17
i'm building a new rig atm. i got a black u2-ufo optimax
this is the bare ally version as its a better picture i went with this in the end, as it only had 5 x 120mm fans & 3 80mm fans.
i wanted the extra drive bays over the extra fans. i didnt want to load a pc so i'm planing to only use the 2 front 120mm fans & the 2 top 120mm fans.
but i have installed all the fans and will see how it runs before connecting them, if i do connect them i was planning
to have them connectioned via just a internal temp monitor
so when its really really hot they come on.
and only have the main 4 fans connected the the aquaero.
Ze@lot
Freitag, 13. Mai 2005, 21:18
i wanted the extra drive bays over the extra fans. i didnt want to loud a pc so i'm planing to only use the 2 front 120mm fans & the 2 top 120mm fans.
Ze@lot
Freitag, 13. Mai 2005, 21:19
dohhh sorry about the extra post, my german is piss poor ;)
Top_Nurse
Samstag, 14. Mai 2005, 01:25
Well I think I would divide them up so you don't exceed the wattage per channel. You still will only have 4 fan channels to use, but if you are creative it will be okay. Also remember you have 6 temp sensor headers and you can program a particular set or sets of fans to do a particular thing depending on the parameters you have set for that sensor.
BTW, nice looking box!
MaxManus
Samstag, 14. Mai 2005, 11:56
I hope for better control ;)
The AC-expansion buses give me opportunity of connection of further fan-channels. How and the limits?
