• 18.11.2026, 20:48
Qix
Aquaero
Donnerstag, 2. Juni 2005, 21:37
Hi guys, i have a problem can anyone help, i have a Aquaero, that comes with jaLCD, but i can`t work with the software, when JaLCDs software starts it shows 2 errors
first error :Error 440 Automatisierungsfehler
second error :Laufzeitfehler 13
since the aquaero usb software works fine, the usb connection is well done, but jaLCDs doesn't work.
thanks in advance
Qix. ps. os:2.02 firmware v4.05e
Re: Aquaero
Freitag, 3. Juni 2005, 00:36
Are you using the new version for series 4 firmware?
You can download it here.
Qix
Re: Aquaero
Freitag, 3. Juni 2005, 00:58
Hi, thanks for your reaction, i use the latest softwareversion from support- download. It seams like the Jalcds software cannot connect with the Aquaero, but the aquasuite works fine.
