• 23.11.2026, 01:01
edboswell
pc71 1800 rad space
Montag, 6. Juni 2005, 17:10
right today i am attaching my 1800 to my case... iv decided to have it so the connectors on the rad are both at the back of the case. Because the rad. is so big it will be dropping off at the bottom... now i have got a feeling and the measurments are showing that the rad is going to be touching the floow before the case. :-[ any ideas on what to do? could i buy some more feet for the lian li case to make it taller.. at the moment i think im just going to have to put some books on the bottom of it lol
Thanks
edboswell
Re: pc71 1800 rad space
Montag, 6. Juni 2005, 17:36
does anyone have a detailed picture (high res) of a 1800 attached to their (or any) case? i have these
http://watercoolplanet.de/index.php?open…genum=1&show=58
but i can't see very much Thanks
Dino
Montag, 6. Juni 2005, 18:14
Maybe that will be helpfull: The airplex evo 1800 have M4 Threads to fix it everywhere you want. Maybe you will find some fittings in a near "do-it-yourself"-store.
Dino
Mr_modnaR
Montag, 6. Juni 2005, 21:35
It looks to me like the rad's mounting holes are part way along the rad's edge so you shouldn't have any trouble mounting it as in the pics you supplied.
if the rad is actually longer than your case is tall, then you don't really have a 'tidy' option, either it'll be sticking out at the top, or sticking out at the bottom, as the following diagram shows:
rock------you------hard place
;D
edboswell
Montag, 6. Juni 2005, 21:54
ok well iv drilled the holes for the 1800... took some pics will post them later
edboswell
Montag, 6. Juni 2005, 22:44
yay i have attached my rad. to the case... but it does touch the floor :-[ will have to think up of someway to make the case higher.
Mr_modnaR
Montag, 6. Juni 2005, 22:46
possibly the wheels for the v-series cases? i'm sure you must be able to get them as a replacement part somewhere!
edboswell
Montag, 6. Juni 2005, 23:00
yes they would be good to have... does anyone have this case... could you possibly measure the height of them?
Thank you
Ed
edboswell
Montag, 6. Juni 2005, 23:25
don't worry about the feet height thing.. iv been looking around the net and found them for $29.99 and i live in england so with postage it doesn't look very good for the money terms. Thinking now of having to re-drill.
Mr_modnaR
Montag, 6. Juni 2005, 23:45
a good example of why you should measure twice, drill once. ;)
edboswell
Montag, 6. Juni 2005, 23:56
they tell me now huh ;)
Mr_modnaR
Dienstag, 7. Juni 2005, 00:03
don't worry, i'm sure everyone's made mistakes, i know i have:
I had just cut the top fan blow hole out (on an Lian Li pc 6065a) to fit in an aquatube, and was filing the edges smooth, and i slipped with the file. Twice.
yeah i know, where were my three layers of masking tape to protect my lovely (ish) case?  :'(
i'm now thinking of putting in an ape 120 grill with a fan on it, just to cover the scratch! (well, actually, to remove it)
