• 15.11.2026, 20:50
enriqueeeee
more images of
Dienstag, 26. April 2005, 21:41
do you have more images of airplex evo 120
and perhaps an autocad drawing or some thing like that from
Einbaublende zum Einbau des airplex evo 120 im CS-901/2001/3001 Gehäuse
so i can see if it will fit ?
pharao
Re: more images of
Dienstag, 26. April 2005, 23:19
Zitat von »NikoMo«
black/grey - outlines bzw holes of the cover / bezel (?? - dunno if that's the right translation)
blue - 120mm fan
rot - airplex chassis
grün - connectors of the airplex
hope this helps a bit ;)
enriqueeeee
Re: more images of
Dienstag, 26. April 2005, 23:24
bezel is right
i kinda ment the bezel with the powersupplie thingy too
http://www.aqua-computer.de/prodimg/nd_p…_blende_500.jpg
that one
and pictures of the radiator from left right back /front connectors
and how thick is the radiator ?
Top_Nurse
Re: more images of
Dienstag, 26. April 2005, 23:25
Can you post the 160 specs here or here: http://forum.aqua-computer.de/index.php?…ad&threadID=396
TIA,
Top Nurse
enriqueeeee
Re: more images of
Donnerstag, 28. April 2005, 00:27
so i can print it ou on paper and make it fit for my lan party
so the one with the psu and the radiator thingy
enriqueeeee
Re: more images of
Sonntag, 1. Mai 2005, 23:35
c'mon
i want to make every thing fit in my new case i want to build but before i can i need some print outs please ??? no one ?
so i know the distance between the rad and the psu to see if its use full
enriqueeeee
Re: more images of
Dienstag, 3. Mai 2005, 22:43
could some one please make a copy of the metal plate with the radiator and powersupply thing on it
so i can see if it is indeed use full i modded my powersupply and its a bit larger then before so i would like to see if it will fit
with the mesurements too please
enriqueeeee
Re: more images of
Sonntag, 15. Mai 2005, 16:35
thanks every one i now know to not order from here if i need mesurements or any thing i can download all the internet and still i havent had an answer which is any help this sucks you guys
Infiltraitor
Re: more images of
Sonntag, 15. Mai 2005, 17:39
I know that there have been a few posts asking for the dimensions of this plate, and so far no answers.
Translating the info from the shop, this plate is designed for Chieftec full tower cases, to replace the PSU/fan panel at the rear.
Another way of getting the dimensions might be to find out the dimensions from the plate at the back of a full tower dragon or something, as the AC plate should be the same.
enriqueeeee
Re: more images of
Mittwoch, 18. Mai 2005, 01:52
yeah thats cool but i need to be sure i'm getting some stuff done with a laser so i need to know if i can use it before ordering its a waste of money if i dont need it ;(
Mr_modnaR
Re: more images of
Mittwoch, 18. Mai 2005, 23:30
what case do you have?
enriqueeeee
Re: more images of
Donnerstag, 26. Mai 2005, 01:47
i'm going to build one of my owne
but it has to have specific dementions so i need to know if it is of any use
Mr_modnaR
Re: more images of
Donnerstag, 26. Mai 2005, 02:12
i don't get it. :-/
you're custom-making your case, and you want to know if an existing part will fit?
answer: buy the part, you then have the dimensions to use for your custom-made case
;) ;D
Infiltraitor
Re: more images of
Donnerstag, 26. Mai 2005, 02:29
^^^I can't argue with that! ;D
enriqueeeee
Re: more images of
Samstag, 25. Juni 2005, 00:27
allthough i wanted to keep my project a secrit here it goes
i've bought a flight case which has internal dementions i have to stay within those or it wont fit
So if my case will be bigger then the dementions becouse the metal plate is too wide
it will be a waste of my ehh 14 euros with which i could buy some other cool stuff like ehhhhh new shoe's for my wakeboard or some thing like that
