• 05.10.2026, 21:22
aviddigi
V2000 SLI Lots of pics
Samstag, 19. März 2005, 08:42
Ok this is one of three computers i built for recent customers of mine. . The video cards are cooled by a single loop eheim 1048 with a HTF-3 Triple X rad and aquatube res. Second loop is cooled by a Rogge mod 86 chevette heater core with plug and cool fittings and cooling works shroud. Paint was done by me using Blue metallic effect that was used on some guys low rider, pics give no justice to the piant but under light looks incredible.
Updated PICS as of 4/12/05 and the computer is for sale!
Lian LI V2000 Case
Custom modded and Painted (Blue Metallic Finish)
Mother Board ( MSI NEO4 SLI )
CPU ( AMD FX-53 )
Memory ( PC3200 OCZ4001024pdc-k )
Video Card ( X 2 BFG 6800 GT PCI Express )
Hard Drive 1 ( 74 GB Western Digital Raptor SATA )
Hard Drive 2 ( 120 GB Maxtor Diamond 9 SATA )
CD/DVD Liteon
PSU ( PC Power Cooling SLI 510 )
WATER COOLING
Aquacomputer Aquastream pump and controller
Eheim 1048 pump ( aquacomputer adapters )
CPU Block ( Aquacomputer Cuplex Evo A64 mounting )
GPU Block ( X 2 Aquacomputer Aquagrafx 6800 )
HDD Block ( X 2 Aquacomputer Titanium Aquadrives )
Reservoirs ( X 2 Aquacomputer Aquatubes )
Radiator 1 ( Water Cool HTF2 X-Triple Revision )
Radiator 2 ( Rogge mod with plug and cool straights )
Aquacomputer Evo 360 Grill
Aquacomputer Aquabay
Aquacomputer Aquatube mounting bracket
Aquacomputer LED mod for Aquatubes ( X 2 )
X 4 Plug and Cool valves (Rogge mod )
Aquacomputer Flow sensor ( Rogge mod )
Aquacomputer Aquaero
Vantec Fan controller
Fans ( X 5 Evercool Aluminum 120 mm fans )
Fans ( X 2 Evercool Aluminum 80 mm fans
Katzenfreund
Re: V2000 SLI Lots of pics
Samstag, 19. März 2005, 08:48
great!
Why do you use so many taps?
Top_Nurse
Samstag, 19. März 2005, 18:41
Ok I plead ignorance ;) What is a Rogge mod? Opened up ID's?
aviddigi
Samstag, 19. März 2005, 19:53
Rogge is my last name and so i just call them rogge mods, the rad for the cpu and HDD blocks is from a 86 chevette and then i welded plug and cool straights on, flow sensor was drilled out (inlet to match the outlet) for better flow. Then the stand i made for the valves. Nothing specail ;D
shonuff
Montag, 21. März 2005, 02:05
Scweeeeeet! Good job on your project. I really like the black and blue theme.
Did you polish your rad? I have the same rad and I have not had a chance to test it yet but plan to soon.
aviddigi
Montag, 21. März 2005, 06:33
Yes i did polish the rad and all the other AC ( evo 360 aquatube bracket etc. ) thanks for the replies also and if anyone is looking to buy this complete setup just pm me, also it will be sold with 2 6800 gt's in SLI but i dont know about the aquaero, as i dont know where in germany it is.
aviddigi
Donnerstag, 24. März 2005, 22:54
Chris at AC went to pick up my aquaero that was lost for awhile in the mail. Id just like to thank AC for sending me a new one within the same day of getting the bad one.
Thanks AC, Dino and Chris also the computer is still for sale
Top_Nurse
Donnerstag, 7. April 2005, 13:25
So where did you put the PSU? It looks like you got a RAD in the area where the PSU normally goes. And where did you get the shroud from that you used in the same area?
Looks sharp! 8)
aviddigi
Freitag, 8. April 2005, 07:24
The PSU is just below the rear 120mm fan, i read you were getting a v2000 on hard forum. The plate that holds the PSU has two 80mm fans also. I just switched put the PSU ontop and the fans below it then installed. Also the 120mm rogge mod rad and shroud are in the front of the case. HDD racks got hacked out and thats were the 1048 pump for the CPU and HDD blocks went.
The fan shroud is from dtekcustoms.com
Also i would like to thank Chris at AC for helping me out with my Aquaero issues
aviddigi
Mittwoch, 13. April 2005, 01:35
Lev
Donnerstag, 14. April 2005, 00:40
better edit your post as "for sale" threads are not allowed in this board...
nice pc anyway
MegaGamer2005
Samstag, 16. Juli 2005, 22:54
Weiss wer was fürn Wasserzusatz er verwendet?
fabelmann
Sonntag, 17. Juli 2005, 00:38
ich dneke es ist einfaches glow motion
aviddigi
Dienstag, 19. Juli 2005, 07:00
Es ist fluoreszierende Markierung Mein Freund
