• 25.11.2026, 22:50
Top_Nurse
Plug & Cool Fitting question
Sonntag, 31. Juli 2005, 08:07
Greetings...
Can anyone tell me the manufacturer of the nickel plated metal G 1/8 and G1/4 90 degree elbows that AC sells? I need some matching connectors in 45 degree elbows and AC doesn't sell them.
Also looking for the same style panel mount connector that has black plastic rings on it instead of the blue colored that they use. Blue definitely does not make it in my latest project. :'(
Stefan_K.
Re: Plug & Cool Fitting question
Sonntag, 31. Juli 2005, 20:07
All AC Connectors are
silver with black ring (metal connectors)
black with blue ring (plastic connectors)
And no .. we don´t tell anyone the manufacturer of the connectors.
Regards
Stefan
Top_Nurse
Sonntag, 31. Juli 2005, 22:34
Well can AC get me some 45 degree metal fittings from wherever you get them from. I know it seems silly to some, but I want all my fittings to match. :)
Stefan_K.
Sonntag, 31. Juli 2005, 23:37
Ask Stephan at info@aqua-computer.de ;)
Top_Nurse
Montag, 1. August 2005, 00:17
Okay I will :) However, the metal bulkhead connector for some reason has a blue ring on it. :'( I need black plastic rings.
pharao
Montag, 1. August 2005, 00:18
paint 'em ;)
Top_Nurse
Montag, 1. August 2005, 01:30
That's a thought. What kind of paint will stick to whatever they made those rings out of?
Tunage
Dienstag, 2. August 2005, 21:31
Just take a black magic marker to'm TN.'swhat I did in a couple instances.
Max_Payne
Mittwoch, 3. August 2005, 00:59
Hy,
Legris (www.legris.com) makes that what you are search
Gruß Max Payne
