• 02.10.2026, 02:50
2grVe
Best way to empty a system
Dienstag, 9. August 2005, 01:28
Hello everyone,
Firstly I can read German but not write it very well (so feel free to reply in German).
I have ordered most of the stuff I need but I still have a question. I have found loads of tips on how a system is filled but none explaining how to drain or refill a system. Is there any little tricks that make this easier later. Does AC or anyone else have fittings, accessories etc that can help?
Thanks...
pharao
Re: Best way to empty a system
Dienstag, 9. August 2005, 11:06
in my opinion the easiest way of draining a system is this:
take a "T-Connector"
and put it to the lowest point in your circuit (if you have an Aquatube -or sth similar- mountet in the front of your computer, put the "T-connector" near the back of the computer).
then a little bit of hose and then you take a cap
and put it on the hose.
to drain your circut take off the cap and put the hose into a bottle or something. Then open up the circut at the highest point (e.g. your reservoir) and watch the water run out of your Sys.
if you really want to go for it, you can buy this one:
all these parts can be found in the Shop at "Zubehör" => "Zubehör zum plug&cool-System"
Top_Nurse
Dienstag, 9. August 2005, 12:39
I ordered a bunch of those valves and some T fittings so I can use one Fillport to fill and bleed my three loops. ;D I also intend to use some to be able to drain my system as well. 8)
2grVe
Dienstag, 9. August 2005, 19:13
Thanks everyone...
Mr_modnaR
Dienstag, 9. August 2005, 21:18
If you do what hobbes suggests, does the essentially stagnant water in the branch of the t-connector cause problems as far as algae is concerned?
cheers
pharao
Dienstag, 9. August 2005, 22:19
cheers
no. ;)
not if your're using acfluid or antifreeze.
here's a pic of my T-connector, it's been running this way for more than a year.
http://www.mi-wgnetz.de/wolf/bilder/Deckel/04.jpg
Mr_modnaR
Dienstag, 9. August 2005, 22:44
excellent news! ;D
Top_Nurse
Dienstag, 9. August 2005, 23:26
If you use black tubing there are no worries with algae. No light...no algae. ;D
