• 01.10.2026, 14:44
vils
All work and no play makes....
Freitag, 12. August 2005, 00:19
Ok Top Nurse and all other here's my project:
Underneath the Lian-Li pc75 case I have mounted a 25mm thick slab of perspex, inside this two 120mm fans are mounted.
Here is the "slab" under work:
very hard to work with but I eventually got it nice looking ;)
Here the fans are mounted and the case partially put together:
even more done:
from underneath:
A pic on the res structure:
Res and rad mounted:
And finally ten pics of everything put together:
/Vils
All work and no play makes Jack a dull boy.
F-arZt
Re: All work and no play makes....
Freitag, 12. August 2005, 00:28
i like the window labeling(?) and the retro-thermometer, nice work :-*
Fotos von Wakü, Tower, etc. http://www.tbechtold.de/modding.html
Jessica
Freitag, 12. August 2005, 01:00
Vils really like your set up looks unique and very classy.
I also think the side panel looks gives your system that renaissance touch be intrested to know more about the top bay thermometer it matches your whole theme a treat. :)
vils
Freitag, 12. August 2005, 01:33
Thanks,
The two top bays are occupied by the reservoir, the thermometer measures the water temp (0-60C). The knob besides it is for the rheostat thats controls the speed of the radiator fans.
I posted it before but it clearly shows the "sleeve" for thermal probe:
The res is filled through the cap on the computer top.
/Vils
vils
Freitag, 12. August 2005, 01:55
By the way, the fonts used att side panel are from a Adler type-writer, the brand Jack Nicholson typed with such frenzy in "the shining" ;)
/Vils
