• 22.11.2026, 22:41
Guffen
Aquaero: Fan make noise at start
Samstag, 13. August 2005, 15:42
When i connect my papst fans to my aquaero there is a sound and the fan will not start before the aquaero sets the power to 20%. Then it can fall to around 5-6% with no problems.
Is there a way I can give the fan 12V for 1-2 seconds just to start it before it go down to low voltage?
Max_Payne
Re: Aquaero: Fan make noise at start
Samstag, 13. August 2005, 15:54
Normaly the Aquaero makes exactly that on start...
Gruß Max Payne
Guffen
Samstag, 13. August 2005, 16:37
How can I test it? Has the same problem with all my fans. All same type.
From aquasuite:
What is the Minimum power in % = 25
Hold maximum power = off
What dos this meen?
