• 07.10.2026, 02:56
A_N_D_Y
Question about AC setup and pump pressure
Montag, 15. August 2005, 06:26
Does anyone think it would be a problem if I used an Iwaki md-20rzt pump with an AC setup?
The AC blocks/res are fairly restrictive (I do plan on using 3/8'' tubing though)...and the 20rzt is a very high pressure pump that I think would help increase the flow rate tremendously. But should I worry that maybe this is too much pressure?
I DO already OWN the pump...So I'd like to not have to buy an aquastream...
D4F
Re: Question about AC setup and pump pressure
Montag, 15. August 2005, 09:58
I dont know this pump, so i cant tell u anything about "pressure" or so, but normaly there should be no problem.
U have got a picture and/or specs ? PM me plz for that, cause AC dosnt like diskussions about noninternal products.
A_N_D_Y
Montag, 15. August 2005, 10:21
I only bring it up because I want to know if I should worry about the ammount of pressure the pump will generate at low flow rates...
http://www.apumpstore.com/magneticdrive/…_WMD_CURVES.jpg
As you can see, its head at low flow is around 7 meters. Someone on another fourm just told me to make sure everything is tight with 3/8'' barbs and metal clamps.
But I also know the pumps you recommend are both low flow and low pressue so I didnt know if those might actually perform better (safer?)
Max_Payne
Montag, 15. August 2005, 12:42
Have you the pressure in BAR ?
Why you don't buy a Eheim 1046 it's one of the quiet pumps.
Greeting Max Payne
D4F
Montag, 15. August 2005, 13:21
^^ Max .... read better .. he HAS got the pump allready .. why he should buy a other??
@ Topic
When i understand the picture ( and i think so ;) ) then u shouldnt worry about "pressure" or so. I dont think a normal and "cheap" pump wich u would use in a PC can produce so much pressure that it would be TO MUCH ;)
Max_Payne
Montag, 15. August 2005, 15:37
Because the Eheim pump is really quiet and cheap... (only 33€)
The picture is about the flowrate in dependence to the hoisting depth
Iwaki MD20RZT:
Max. SYS Pressure 14,2 PSI (pounds per square inch) = ~0,979 Bar
I think it would be work..
Greeting Max Payne
