• 01.10.2026, 20:53
Ze@lot
fill ports
Sonntag, 28. August 2005, 11:35
any1 know if the DD fillport can be converted to take the AC plug & cool fittings ??
Ze@lot
Re: fill ports
Sonntag, 28. August 2005, 11:45
Beun
Re: fill ports
Sonntag, 28. August 2005, 15:10
It's time AC makes their own fillport :)
Hummerman
Re: fill ports
Sonntag, 28. August 2005, 15:21
The Aquatube is the AC fillport.
Ze@lot
Re: fill ports
Sonntag, 28. August 2005, 15:53
yep. but i got 2 aquatubes with aquajets running on 2 loops, just think im gonna have some fun filling them without maybe a fill port.
wish AC could make one for there system
Beun
Re: fill ports
Sonntag, 28. August 2005, 19:00
The aquatube is a reservoir and thus big. In a lot of cases it is convient to add a fillport to achieve easy filling and reaching the highest point in your systeem :)
Hummerman
Re: fill ports
Sonntag, 28. August 2005, 19:13
In Germany all use the Aqautube to fill the system.
I hava a Aquatube with Aquajet and no problems to fill the system.
fabelmann
Re: fill ports
Sonntag, 28. August 2005, 20:21
if you are afraid of the water from the spülleitung, push a PVC hose over the output of the spülleitung and put the other site in the resevoir.
next idea: put a bottle over the spülleitung, so the water can't exit from the resevoir
Ze@lot
Re: fill ports
Sonntag, 28. August 2005, 20:37
cheers. id been told b4 of the bottle over the aquajet, so i take it then that i can fill one loop at a time ?
Top_Nurse
Re: fill ports
Sonntag, 28. August 2005, 23:12
The reason I used a Fillport was because I didn't want to tilt my computer on its back to fill it with cables hanging on the back. I also intend to be able to fill and bleed all three independent loops from the one Fillport. 8)
Beun
Re: fill ports
Montag, 29. August 2005, 09:48
In my case the aquatube is not in the highest place of the case (even when tilted). A fill port is the best answer in this case, even in Germany ;)
Ze@lot
Re: fill ports
Montag, 29. August 2005, 14:48
allowing for the size & weight of my pc case at the moment,
id need 4 people to help me fill my case if i use the aquatube.
edboswell
Re: fill ports
Montag, 29. August 2005, 21:10
maybe you should go to the gym ::) i think 2 people is enough (i have the 1800 rad so don't start telling me what heavy is) :P
Re: fill ports
Dienstag, 30. August 2005, 14:13
My Aquatube is not the highest point.
Anyway, I fill my system with the Aquatube.
And finally I live in Germany.
Whooaaar :o ;)
Beun
Re: fill ports
Dienstag, 30. August 2005, 21:53
Is your aquatube not in the highest place even when you tilt your system? In my case the aquatube is never in the higest place even when I tilt it in all directions, even in Germany hahahaha :)
Ze@lot
Re: fill ports
Donnerstag, 8. September 2005, 18:47
found these might give them a try
they do a 10mm x 1/2 Bsp Taper straight fitting that might just do the job
Beun
Re: fill ports
Freitag, 9. September 2005, 09:09
Sounds good, please let us know what the results are :)
Stefan_K.
Re: fill ports
Freitag, 9. September 2005, 13:04
Sorry Guys,
please don´t post links to other shops or companies in this forum.
thx
Stefan
