• 30.11.2026, 15:51
Mr_modnaR
ATX Questions
Mittwoch, 28. September 2005, 11:13
Hi all...
got two for you today:
1. On the 20 pin atx plug, which two pins is it that you need to bridge to turn on the power supply, you know, like the one that AC sells.
2. if you have a 24 pin atx plug which has a 4 pin bit on the end that you can detach to make a 20 pin plug, does the 4 pin part have a permanantly on power line that you could power the aquaero with even when the computer is off, like the PS_ON line that they recommend to use?
many thanks
Stefan_K.
Re: ATX Questions
Mittwoch, 28. September 2005, 13:53
1. black and green
2. no
Mr_modnaR
Re: ATX Questions
Mittwoch, 28. September 2005, 16:41
many thanks Stefan! does it matter which black?
oops i think that the PS_ON line is to turn the power supply on and off, is it not? (D- bad research! ;D)
Re: ATX Questions
Mittwoch, 28. September 2005, 17:17
No, they are all the same.
Mr_modnaR
Re: ATX Questions
Mittwoch, 28. September 2005, 21:25
cool, cheers shoggy
