• 22.11.2026, 22:59
edboswell
aqua drive quietness..
Donnerstag, 13. Oktober 2005, 12:54
hi will the aqua drive (dual or/and single) provide me with any sound insulatingness - e.g. will it make my harddrive sound quieter or is its purpose soely to cool the hard drive. Thanks
B.
Re: aqua drive quietness..
Donnerstag, 13. Oktober 2005, 16:24
It will decrease the sound of your harddrives.
There is sound proofing material inside -> *click me*
edboswell
Donnerstag, 13. Oktober 2005, 20:07
ok thanks :) - i take it that its for both the single and the dual?
Donnerstag, 13. Oktober 2005, 20:52
Yes ;D
Top_Nurse
Freitag, 14. Oktober 2005, 14:40
Thanks for the pics Shoggy! I always was interested in what was inside an Aquadrive. ;D
Ze@lot
Freitag, 14. Oktober 2005, 19:02
that's a black anodized aquadrive ?
was it made for you or did you strip off the blue & have it anodized after ?
also my aquadrive did not have the large blocks of foam was these fitted after ?
Freitag, 14. Oktober 2005, 19:20
The bigger foam blocks were installed in addition.
Color -> it's a normal titan version. Maybe the bad illumination makes it a bit black ;)
Stefan_K.
Freitag, 14. Oktober 2005, 20:04
It is black ..
the guy who took the pictures anodized it in black.
Only blue is available in the shop.
Cheers
Stefan
Freitag, 14. Oktober 2005, 21:47
Aquadrive titan vs. Aquadrive above
edit: maybe you forgot that it was available in titan? ;)
Top_Nurse
Freitag, 14. Oktober 2005, 23:54
So why not make it available in black? Black is VERY popular here in the USA. The black Aquatubes sell out almost immediately. :o
Ze@lot
Samstag, 15. Oktober 2005, 01:08
cool so the blue is just paint that i could strip off if req'd ?
Samstag, 15. Oktober 2005, 05:16
Not really ;)
It's anodized.
Top_Nurse
Montag, 17. Oktober 2005, 01:13
You can have the blue stripped off prior to having it re-anodized in the color of your choice.
