• 13.10.2026, 08:33
Top_Nurse
Dual LED Aquaero question
Montag, 17. Oktober 2005, 12:26
Anyone know if I can run two or three sets of Aquaero Dual LED's off the same Aquaero LED connector?
I have three Aquatubes in FF and it would be nice if I could have the same lighting in all three if possible.
x-stars
Re: Dual LED Aquaero question
Montag, 17. Oktober 2005, 13:39
As far as I know is it possible to connect at least 2 LEDs per connector (=4 LEDs=2 Dual-LEDs).
If you wish to connect more, you can do it by
1) using the multiswitch
2) using a small circuit with an opto-coppler (is this english? ::))
Mr_modnaR
Montag, 17. Oktober 2005, 16:35
opto-coppler (is this english? ::) )
opto-coupler (this is english ;D)
(or opto-isolator)
Top_Nurse
Dienstag, 18. Oktober 2005, 11:37
I forgot all about opto-couplers as I hadn't used them in a few years. They were used in my astronomy camera to connect it to an autoguider circuit on my mount. Isn't the opto-coupler either on or off only? I didn't think you could modulate the device so as to get a variable output. Or is there some way around this?
Will the Multiswitch give me the same dual LED light change from green > yellow > red as the Aquaero is programmable to do?
x-stars
Dienstag, 18. Oktober 2005, 13:16
In the product description it's said, that the LED-connectors are dimable - I have no clue if there is a chance to dimm the LEDs by temperature, but if it's not already done, I'm pretty sure it will be done ::).
Mr_modnaR
Mittwoch, 19. Oktober 2005, 10:57
yes i thought that too...
Top_Nurse
Donnerstag, 20. Oktober 2005, 09:36
I have to call my friend Sheila up at CSULA and ask her as she is an electrical engineer. I think there might be a way to modulate the opto-coupler with an analog signal. Let you know in a few days if it is possible.
Top_Nurse
Samstag, 22. Oktober 2005, 15:39
Okay I need to know some more technical info about the LED output of the Aquaero. Is it a PWM or analog output?
IOW, what is changing when the Aquaero commands a dim or brighten sequence? Voltage or PWM?
Mr_modnaR
Samstag, 22. Oktober 2005, 20:28
almost definately, i'd guess analog.
if it were PWM, then you'd notice the leds flickering like an old tv set out of the corner of your eye!
Top_Nurse
Sonntag, 23. Oktober 2005, 12:30
Okay assuming it is analog then what is the maximum milliamps that the circuit can take without letting the magic smoke out? IIRC the Aquaero LED output is extremely bright. So much so that I decided to run my LEDS in through the sides of the Aquatubes. So I am wondering if the circuit can handle three pairs of LED's (6 total) at a less ampount of brightness?
Mr_modnaR
Sonntag, 23. Oktober 2005, 14:21
well you could measure the single led's current draw, and then calculate what resistor you have to put in to keep it the same for three. (i assume you mean six leds as in three on each channel?)
