• 18.11.2026, 02:25
Top_Nurse
More on Tubemeters
Donnerstag, 27. Oktober 2005, 11:49
So does anyone know what the Tubemeter Aquabus cable is for? Looks kind of like a USB with a power connector attached? Are all Tubemeters USB devices? Do I have to have the Aquabus cable + the USB cable?
x-stars
Re: More on Tubemeters
Donnerstag, 27. Oktober 2005, 14:17
When you order a tubemeter, you get the tubemeter and a USB-Connection-cable.
But if you have an aquaero, you might have the wish to connect the tubemeter to the aquaero _instead_ to the usb-port - then you must add the auqabus-cable to your order.
Id the tubemeter is installed to the usb-port, it will be an own device in the aquasuite (like the aquaero).
If it's installed to the aquaero, it will be shown in the Tab "Tubemeter" in the Aquaero-Part.
Beun
Donnerstag, 27. Oktober 2005, 20:28
With the auqabus-cable can it be mounted directly to the aquaearo? or do you need a auqabus?
Donnerstag, 27. Oktober 2005, 20:49
The aquaero has a aquabus connector. You can use this connector to add several aquabus devices like multiswitch, tubemeter etc. There can be up to 64 devices at the aquabus. You don't need more than aquaero, aquabus-cable and the tubemeter. The cable for the tubemeter is special, because the aquabus doesn't supply the tubemeter with power (USB does it). So you also have to connect it to the PSU.
The firmware of the tubemeter detects if it is connected to the aquabus or USB. So you don't need other tubemeter versions and you are free to change it to USB at any time.
Top_Nurse
Donnerstag, 27. Oktober 2005, 22:15
So what is the best way to hook it up?
Beun
Donnerstag, 27. Oktober 2005, 23:07
Thanks Stephan, finally I understand. I'll order it this weekend :)
x-stars
Freitag, 28. Oktober 2005, 15:24
I would guess the aquabus, because you can add it to your "emergency shutdown settings" (so the aquaero can shutdown your PC when the tube loses his content :D).
Top_Nurse
Freitag, 28. Oktober 2005, 15:40
Thanks for the answer. :)
So how do I wire multiple Tubemeters to the Aquabus? The cable set I ordered only had what looked like one set of connectors. Can I wire that in parallel to another Tubemeter and have it recognized as an independent device?
Top_Nurse
Dienstag, 1. November 2005, 10:53
^^^ Anyone?
Do I also gather I can use the Tubemeter upside down like seen in this pic:
x-stars
Dienstag, 1. November 2005, 11:22
^^^ Anyone?
Otherwise it wouldn't be mentioned by AC (this is an original-AC-pic -> so, yes you can :)).
Top_Nurse
Dienstag, 1. November 2005, 13:28
What about if I wanted to use a Tubemeter that is sitting at say a 15 degree angle from straight up and down like in this pic:
Mr_modnaR
Dienstag, 1. November 2005, 15:28
i should think it'd work, all the tubemeter is is a row of moisture sensors on a stick, so basically it'll give you a measurement of the water height whichever way up it is, the only problem being that its range of measurement decreases as you move it towards the horizontal plane.
x-stars
Dienstag, 1. November 2005, 17:04
I think it could work, if you make an fix in the software (I'll write to Sebastian - I'll get the same problem when everything should work as I planned ::)).
Mr_modnaR
Dienstag, 1. November 2005, 19:48
yeah, something like a row of buttons to select what angle/position the tubemeter is in.
Top_Nurse
Mittwoch, 9. November 2005, 11:04
On the Tubemeter I found what appears to be a "1" next to one of the pins. I assume this is pin 1, but is it pin 1 per the USB specification wich is positive or is it the Aquaero type pin 1 which is negative?
