• 02.10.2026, 19:32
MUFFDIVER
Help
Donnerstag, 10. November 2005, 16:55
ok my pump controller thingy was smoking last night and need to start the pump but dont know what to do.
its knacked so how do i start the pump without using the controller.
Re: Help
Donnerstag, 10. November 2005, 17:04
You can't run the pump without the controller. The pump is using 9 volt alternating current with a frequence between 42 and 74hz. You would have to use a transformator with exactly this output.
MUFFDIVER
Re: Help
Donnerstag, 10. November 2005, 17:14
Ok i have a second controller can it run 2 at the same time?
Re: Help
Donnerstag, 10. November 2005, 19:09
No, the load would be too high and finally you would have two defective controllers ;)
MUFFDIVER
Re: Help
Donnerstag, 10. November 2005, 19:11
so whats the order number for the controller as i cant find it in the shop?
Hummerman
Re: Help
Donnerstag, 10. November 2005, 19:14
95077 ;)
