• 13.11.2026, 06:21
MUFFDIVER
Did A dumb thing!
Montag, 14. November 2005, 16:29
Ok i wanted to mount a 360 radiator to the under side of my pc. this i though easy then ounce i looked properly i realised i would have to re drill hole for mounting so the rad will face upwards. so i decided to drill to what we commonly know as the unerside. was all going well till i accidently didnt set the measure thing on the drill so when it broke through it went through 1 of the pipes. SH!T  :o .
So any suggestions on how i am going to repair this little accident. I need to patch a hole the size of a 4mm drill piece.
How shud i do it, n e 1.
P.S will post pics so you call all have a laugh @ me. ;D :o
Ze@lot
Re: Did A dumb thing!
Montag, 14. November 2005, 20:35
me laugh, never ::)
i've never had to use this guide so i cant say for sure if it works but looks a sound way of fixing it.
http://www.wizdforums.co.uk/showthread.php?t=2909
hope ya get it sorted
Infiltraitor
Montag, 14. November 2005, 21:51
Leeum's a good guy - it should work fine ;)
Katzenfreund
Montag, 14. November 2005, 21:55
If I caught you problem, you have a hole in one of the pipes.
(in the 2 short parts of the pipes outside or in the part inside?)
What helps mostly is soldering it.
Or some times it is enought to use some "Teflonband":
-> That stuff:
MUFFDIVER
Montag, 14. November 2005, 22:06
just waiting on the acryl to set as i have used that after the solder. just to make sure. will let ya know if it leaks ::)
