• 05.10.2026, 17:43
Beun
Mounting position tubemeter USB in aquatube
Samstag, 19. November 2005, 20:25
When fitting the tubemeter in the aquatube water reservoir, I end up with the side with the led not facing the window.
Does anybody have the same problem and possibly know a solution?
Katzenfreund
Re: Mounting position tubemeter USB in aquatube
Sonntag, 20. November 2005, 09:26
Your Problem is that you cannot see the LED of the tubemeter in your Aquatube?
Which point did you use? The sided or the ground once? (It doesn't matter for the function of the tubemeter)
Beun
Sonntag, 20. November 2005, 11:17
Yes, tha't's the problem.
I've mouted the aquatube in a bay and used the ones that are on the bottom then (the middle one).
