• 15.11.2026, 00:52
MUFFDIVER
evo 1800 rad
Donnerstag, 17. November 2005, 18:50
Is there going to be a mounting plate for this?
fabelmann
Re: evo 1800 rad
Donnerstag, 17. November 2005, 19:27
no, i don't think so. when i was talking to stefan k. from aqua computer berlin, he said, that mounting a 1800 rad on the side of your case is possible by 4 m4 scews and some "Abstandshalter" ( bolts, which are several cm long to make some place between case and rad)
like that one, but you do'nt have to choose the bolts that long, depending on what you are cooling
MUFFDIVER
Re: evo 1800 rad
Montag, 21. November 2005, 04:20
hmm water speed must be slow with the 1800?
edboswell
Re: evo 1800 rad
Montag, 21. November 2005, 14:17
nope with a decent pump - eheim 1048 the water goes round my 1800 pretty fast - with 6 blocks to go through... the water is sprayed onto the res. quite effectively. I bought the aquero (will flow meter thing) so i will post the speeds as soon as it arrives :)
MUFFDIVER
Re: evo 1800 rad
Montag, 21. November 2005, 14:30
cheers mate 8)
Mr_modnaR
Re: evo 1800 rad
Montag, 21. November 2005, 20:40
Be warned tho, it IS larger than most cases, so get it if you don't mind an overhang!! ;D
MUFFDIVER
Re: evo 1800 rad
Mittwoch, 23. November 2005, 17:43
im stripping to crp pcs down and using the frames or chassis, and using mdf to make a frame for it,understand that as i lost my self in it. il post a thread when i start it :)
MUFFDIVER
Re: evo 1800 rad
Freitag, 25. November 2005, 01:46
so will 5 360 mounting covers fit the 1800 as it lookslike it just might?
edboswell
Re: evo 1800 rad
Freitag, 25. November 2005, 11:36
yes they will but are you going to buy 15 fans... i have got fans but only very quiet ones ... and they come at a price.. about £15 a fan inc vat. - do the maths 15*15= £225... not worth it if you ask me... i might get 15 over time (1 a month) but not in one go. You do not need them just for protection it is not needed... if you think it is then you don't take enough care over your computer....
MUFFDIVER
Re: evo 1800 rad
Samstag, 26. November 2005, 17:49
How So?
