• 26.11.2026, 08:41
firmwareupdate (FW1.06) for tubemeter
Freitag, 2. Dezember 2005, 13:38
A few people had the problem that the tubemeter is showing a too high fill level. The new firmware fixes this problem.
You can download firmware 1.06 here.
You have to connect the tubemeter to a USB port if you want to flash it. Close all unnecessary applications, start the Aquasuite and flash the downloaded file.
After flashing the tubemeter it will log on to USB again; if not you have to shutdown your pc (off) and start it again.
Top_Nurse
Re: firmwareupdate (FW1.06) for tubemeter
Freitag, 2. Dezember 2005, 15:59
So is there some kind of circuitry inside the Tubemeter casing? Or does the flash procedure just update the Aquasuite software?
x-stars
Freitag, 2. Dezember 2005, 16:11
It updates the µC's flash with a new firmware (old firmware was 1.5 - you can see that only, when the tubemeter is connected to usb) :).
Katzenfreund
Freitag, 2. Dezember 2005, 16:17
If it would just update the Aquasuite, it woudn't be necessary to conect the tubemeter via USB.
So you see: There is a flash on the tubemeter.
Top_Nurse
Freitag, 2. Dezember 2005, 16:55
Wow! That Tubemeter is cheap for having a flash device inside it. :o
Katzenfreund
Samstag, 3. Dezember 2005, 08:29
maybe flash was not the right word.
Let's say this way: A re-writable chip.
Mr_modnaR
Samstag, 3. Dezember 2005, 11:55
EEPROM?
Samstag, 3. Dezember 2005, 14:44
It's FLASH-Meomry - no EEPROM ;)
x-stars
Samstag, 3. Dezember 2005, 14:52
You can get lots of µCs with flash for less an Dollar ::).
Mr_modnaR
Samstag, 3. Dezember 2005, 15:36
i thought eeprom had a flash chip inside? oh well :(
Beun
Samstag, 3. Dezember 2005, 21:17
Is it possible to flash when attached to the aquaearo?
x-stars
Samstag, 3. Dezember 2005, 21:55
No, it's not - that's why it was mentioned to connect it to USB :P.
(Had the same problem: Tubemeter was connected to the auqaero and it was not easy to get the usb-cable plugged - not much space in my pc :)).
