• 19.11.2026, 07:38
nahyah
ramplex help
Freitag, 16. Dezember 2005, 07:29
i just got my ramplex and im having difficulty putting it together. i've tried several different configuration and still cannot find a way to mount it. how do you use this and how do you use the 3rd plate to cool the other memory?
Stefan_K.
Re: ramplex help
Freitag, 16. Dezember 2005, 11:36
you have 4 plates. 2 for each ram module.
First mount two plates so you can still slide the ram module between. then press the plates towards the module to fix it. Repeat this on the second module.
For 3 modules you need another set of 2 plates.
Cheers
Stefan
MUFFDIVER
Re: ramplex help
Samstag, 17. Dezember 2005, 09:08
it is a bit fidly at first but its like anything ounce you have done it, its easy!!!
no serious if you still have ne problems take a look at a thread called *2x Ramplex - 4 DIMM's fits on DFI NF4 SLI-DR?* page 3 and i think there is a diagram on it somewhere...
hope this helps.
