• 30.09.2026, 00:47
Top_Nurse
SLI Typ 1 problems
Dienstag, 17. Januar 2006, 21:07
Anyone else had problems in getting the 8mm compression fittings to work with the TwinPlex Pro SLI Typ 1 cooler?
Top_Nurse
Re: SLI Typ 1 problems
Mittwoch, 18. Januar 2006, 10:59
No one has had any problems or no one else has tried to use the G 1/8 8mm compression fittings?
Here is my problem:
I think I can turn down the nuts, but I am wondering if others have had the same problem.
CygnusX1
Mittwoch, 18. Januar 2006, 11:23
As you know AC uses 8/6mm and your fittings are simply too big. They won't fit, but you can try do put in one fitting with an angle, perhaps it fits then. I have 8/6mm fittings and they are very close, but they fit.
MUFFDIVER
Mittwoch, 18. Januar 2006, 20:43
Yeah looks dodgy i must admit... Umm... dont know how to help TN sorry.
melon
Mittwoch, 18. Januar 2006, 21:54
Take ONE of these and it will work!
(Ps: man kan über treiben)
Top_Nurse
Mittwoch, 18. Januar 2006, 23:01
MUFFDIVER
Donnerstag, 19. Januar 2006, 00:12
Check you out. 8)
melon
Donnerstag, 19. Januar 2006, 01:22
8)
;D
