• 29.11.2026, 15:25
CometMan
Jalcd Problem again
Samstag, 11. Februar 2006, 23:47
i am having problems whit jalcd again, from one day to another it stoped working, whit no apparent reason, it doesn`t startup whit windows and gives me the error 91, and error in line 3 of the example,i unistalled and installed it again and i installed the fix .dll, but it keeps giving me the same errors :'(, today i booted up my machine and jalcd started up normaly displaying normaly, rebooted and it wasn`t working anymore
please help out ::)
Re: Jalcd Problem again
Sonntag, 12. Februar 2006, 01:28
Do you start it with the correct parameter?
'X:\...\jalcds\jaLCDs.exe output=aquaerolcd.jaLCD'
CometMan
Mittwoch, 15. Februar 2006, 19:37
sorry i didn`t understand what should i do or check! please explain it
cheers
Mittwoch, 15. Februar 2006, 22:39
Go to your jaLCDs folder, right-click on the jalcds.exe and create a shortcut. Go into the properties of this new shortcut and set the target to 'X:\...\jalcds\jaLCDs.exe output=aquaerolcd.jaLCD'.
You will have to exchange X:\...\ with your path ;)
Now you should be able to start jaLCDs with that new shortcut.
